Hey,
I've ordered a WD Scorpio Black (as I can't afford a huge SSD yet
) to put in my MBP, ideally I'd like to clone my existing OSX install rather than doing a full re-install. Is this possible by using the recovery feature on the OSX install disk? I've found some guides but I wanted to make sure it was as simple as putting the new HDD in an external USB caddy, booting from the Snow Leopard disk, select recovery, point source at existing Macintosh HD and point destination at the WD Scorpio in the USB caddy and then replacing the existing HDD with the new, cloned HDD?
In theory it should work, but I wanted to check that I didn't need to partition the disk/repair permissions/etc.
Thanks
) to put in my MBP, ideally I'd like to clone my existing OSX install rather than doing a full re-install. Is this possible by using the recovery feature on the OSX install disk? I've found some guides but I wanted to make sure it was as simple as putting the new HDD in an external USB caddy, booting from the Snow Leopard disk, select recovery, point source at existing Macintosh HD and point destination at the WD Scorpio in the USB caddy and then replacing the existing HDD with the new, cloned HDD?In theory it should work, but I wanted to check that I didn't need to partition the disk/repair permissions/etc.
Thanks
