MBP Keyboard key popping out?
12 Mar 2003
Quick advice please
The downarrow on my MBP pops out if I press it near the top left corner of the key. It's hinged on still but annoying as it doesn't press correctly then flips up if I hit it wrong.
Any easy diy fix or do I need to take it into an Apple store? I don't want to send it away for repair on something fairly trivial
Next time it pops up I'd try very carefully to remove the key - search on how to do this properly as you may bend the scissor switches underneath if you aren't careful. Check if anything is broken, then pop it back in. Otherwise, best bet would be to look at replacement keys, or if in warranty, head to your local Apple Store to get it sorted.
