atomiser
atomiser
so i want to try to keep the battery on my new mac in tip top condition. i thought the process went like this:
use the mac disconnected from the mains until you are warned about being on reserve power... then, continue to use until the mac goes into sleep mode... let the white light pulse on and off for up to 5 hours, at which point the battery should be completely dead.
then, connect to the mains and charge until the magsafe adaptor turns green... continue to charge for a further 2 hours, and then you are good to go - battery nicely conditioned. rinse and repeat every month to keep things in good nick.
so... i appear to be failing at the first hurdle... a while after being informed im running on reserve power my mac just dies completely. i don't get any sleep mode pulsing on and off... if i charge the battery completely, when powering the mac back on it 'resumes' rather than booting from scratch.
what am i doing wrong? cheers.
