MBP - Replace HDD with a 7200rpm....
That's got to be the biggest load of crap I've read in a long time!
On that basis my MBP would still say it's got a Toshiba drive in it.
Copied from system profiler :
Intel ICH7-M AHCI:
Vendor: Intel
Product: ICH7-M AHCI
Speed: 1.5 Gigabit
Description: AHCI Version 1.10 Supported
SAMSUNG HM250JI:
Capacity: 232.89 GB
Model: SAMSUNG HM250JI
Revision: HS100-08
Serial Number: S0TVJD0P618710
Native Command Queuing: Yes
Queue Depth: 32
Removable Media: No
Detachable Drive: No
BSD Name: disk0
Mac OS 9 Drivers: No
Partition Map Type: GPT (GUID Partition Table)
S.M.A.R.T. status: Verified
Volumes:
Macintosh HD:
Capacity: 232.57 GB
Available: 6.18 GB
Writable: Yes
File System: Journaled HFS+
BSD Name: disk0s2
Mount Point: /
Its just a case of choosing one, some review sites like the Hitachi, some like the Seagate. Just go through them a pick the one you want.
Have purchased the hitachi based on the info here and around the net. Will have it in a few days.
Hopefully its the right purchase.
And so I now have the 200gb hitachi drive in my macbook. Along with 4gbs or ram hehe.
How should I test this then?
It's actually not that hard to replace the HDD, it's just fiddly.
Oh and FYI, if you can do it without damaging the innards you only have to repeat the process and put back your original HDD if you want Apple to service it.
Follow the guide on http://www.ifixit.com/guides :)
I've said before, some 2.5" drives won't fit properly and cause the case to bulge because they're too thick, I know the seagate drive will fit but I can't vouch for any others (except to say that a fujitsu drive I tried would not fit)
