Hi,
I have a mid-2009 MBP and am noticing it seems to be running a lot hotter than it used to. (and it runs a lot hotter than my work machine which is a i7 MBP with an SSD) The warranty expires in June so keen to do something about it before then.
Has anyone had a similar thing or taken theirs to the Apple store for something like that? or have you indeed re-thermal pasted it yourself? Is it something the Apple store guys are likely to acknowledge and address? Both the fans seem fine and the laptop is not really very dusty inside at all.
Thanks
Thanks
