MBP Slown Down
18 Oct 2002
Hi All
My MBP Has slown down quite a bit dont know why and boot up not as fast is it cost it been used and got MS Office installed or does it need cleaning what tips is there please to get it at peak again
Cheers
Go to each of these folders and completely empty them both.
Home>Library> Caches
Macintosh HD>Library>Caches
This will delete all of the cache files, and should speed things up a bit (first reboot might be a bit slow), or alternatively you can check out Onyx or Tinkertool in the sticky :)
