has anybody tried 8GB on their Unibody MBPs running Snow yet?
Just wondering if it will be stable and make use of the full 8GB as ive read some only work with 6GB?
I have 4GB in my MBP and it doesn't max out for the apps I run, so depends if you ever find it maxed out on your system as to whether you would actually use it?
Well, do you max out the ram you currently have installed? I would assume if you did you would notice a nice difference. If not, then you will not see any real difference.
