'lo all,
Was hoping someone could help me out of a very tight spot, my main system with months worth of work has just gone down due to a fault in non-paged area BSOD. On rebooting it started to load XP but said the system/config was corrupt.
It tried fixboot which didn't work. Tried fixmbr which didn't work and now rendered the drive inaccessible. Tried chkdsk which said there was an unrecoverable problem. I then tried a repair install but, because of the mbr issue, it said there was a problem with the partition and wouldn't install. Tried hooking up as a slave on another system but shows it as unformatted.
I've spent all day reading/trying to fix. I think it's recoverable because it was trying to load XP before I stupidly fixmbr'd it
There's a program called MBRwork that seems like it has a good chance of working but I'm worried about doing any further damage - the idea behind mbrwork is it zero's the MBR then re-writes and 'standard' MBR. I would just like to know will zeroing the MBR effect the data?
Or if anyone has any other ideas...
