Mbr woes
12 Apr 2007
I've been pratting about with Linux but I think I've somehow lunched the mbr on my windows drive..
I can see the drive from windows USB instalation media /cmd but I can't seem todo anything with it.
It shows in bios but not on the boot order section.
Any ideas or do I just have to reinstall Windows?
I've disconnected all drives apart from the windows drive to keep things simple
If it's genuinely still an MBR format drive than you need the BIOS to be set to CSM rather than UEFI to boot.
Diskpart "list disk" will show whether it is GPT format or not
And if it is then you should convert it to GPT with the following commands:
mbr2gpt /validate /allowFullOS - this checks the process
mbr2gpt /convert /allowFullOS - this actually converts it
then set the BIOS back to UEFI boot
I think it's already uefi... There's a star under GPT?
Disk 1 Is My USB windows installer
To be honest I wouldn’t prat about with Linux as a booting operating system. It’s fine to run in a VM, I’m a newbie and it’s easy enough to find the terminal commands you need to install things.
One of the most important is to install VM tools to allow you to set resolution properly, I use VMware for virtualization.
got fed up in the end and just did a fresh install. its only browser bookmarks and a few steam games that needed to be added back - steam is pretty cool in that you can install games from other PCs on the network - super install speed!
Thanks for the help though.
I want linux installed properly as I'm moving over from windows - I'll still maintain a windows instalation for the time being but it'll just be basically sand boxed and just fired up for the odd thing I cant do on linux.
