MBX-130 and MBX-143 differences?
18 Oct 2002
Wellington, NZ
Hi does anyone know the differences between these two motherboards? Also Would they both fit in the same case? PS I have a VGN-FS315B will other better motherboards fit in it?
Thanks,
i think the fs series came with either GF go 6400, 6200 or intel graphics all integrated on board, they should physically be interchangeable but i think yours is the highest spec anyway. but if you did swap it the graphics heatsink might not fit as the gpu will probably be in a diferent place on the mainboard.
