Hey Guys
I've been asked to remove a virus off a PC (it's a Dell Dimensions E520 with Windows Media Center on, though I'm not entirly sure if this is the original copy of windows that came with it, or something someone else has put on at some point) but I've since found another problem with the PC. Windows just seems to freeze at the welcome screen in both normal and safe mode about 90% of the time I try to boot up, with the occasional time will actually get onto the desktop before freezing while loading startup stuff.
Now I don't think the PC is actually frozen because I can still use the mouse etc, it's like the HDD has just had enough and stops loading anything. I have ran a chkdsk /f on the drive while connected up to another PC and that found no errors, the western digital software has found no problems with the drive so I'm wondering whether theres something broken in windows? It also could be the virus and tonnes of other crap thats been installed thats slowing the PC down
Do you think it would be possible to repair windows using an XP pro SP3 disk on this version of media center? As far as i know MCE is just XP pro but with the media center app added? the MCE version installed on the PC also has SP3 installed.
Any thoughts or ideas are welcome
