So I've installed an MCP35X in a koolance RP-402X2. I've filled the loop with water though there's still in it. I switch on the pump and water starts flowing normally. However after a short time like 1 minute the pump starts to make a very load noise like it's hitting something and I have to switch it off. If I switch it on again immediately after it works for around a 1 minute and it starts to do the same noise.
I've checked and there is nothing stuck in the pump's impeller. I'm starting to think maybe I'm screwing it too tight to the resorvior mounting.
When I'm back home I'll try to loosen the screws and if that does not work I'll try to use the pump on its own without the reservior.
Anyone got some suggestions as I'm totally lost on what could be the problem.
Thanks in advance for your time.
