Mcubed T-balancer
17 Dec 2004
Crawley, WEST SUSSEX
Hi,
Just wondered if anyone has this if they could tell me how many fans I can control from it? As I will have around 5 fans in my new computer and I like the idea of doing all the fan controlling via software instead of turning knobs on my akasa fan controller.
Thanks
4 fans, but with the splitters (available seperatly) you can get upto 8 controlled in pairs.
I have one and its a superb bit of kit, overkill for my current needs though.
Cya,
Sam C
They are absolutely the best way to control your temperatures. Have a look at the mCubed website, READ the manual and check out the software. It's awesome.
There is one for sale on MM at the moment (not mine) with loads of extras.
Yep there sure was but guess who snapped that up :p
If you do a search k3v I am sure you'll come across a website that does them, they maybe out of stock at the moment but I emailed them and they are getting stock in soon. Email me if your having problems finding them. The actual T-balancer is around 35 quid.
thanks for the reply, ill have a look when I get home. i m browsing on my phone which is why I asked for a price....
cheers though
Right had the mail back from the shop and apparently there is a new T-balancer being released called the BigNG. From what I can see on the Mcubed website it doesn't have too many more features, think the 2 that I can spot are that you can choose between analogue and PWM and it can control upto 8 analoge sensors. Also the case now has a hole in it to acommodate what looks like a heatsink.
Do point out anything else you guys see thats differeant. Personally I am happy I got the MM one as I can't see these new ones being cheaper than the old balancer and I got a load of goodys with the MM one.
