mdadm RAID1 Recovery
KIA
KIA
Man of Honour
14 Nov 2004
Hi,
I had to break up a RAID1 array.
When it came to recreating it using mdadm, I accidentally used --create instead of --assemble.
The file system is ext3. When I try to mount the array:
root@debian:~# mount -t ext3 /dev/md2 /root/temp/
mount: wrong fs type, bad option, bad superblock on /dev/md2,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
Am I screwed? Is my data gone?
Did you get it to assemble correctly?
It has most likely fubared the filesystem headers though im afraid. As it's just RAID1 the actual data should in theory be fine and a recovery program should work quite well.
In any case, I would look at running testdisk on it, it supports partition and data recovery for both ext3 and linux software raid1.
I'm not sure which is the best testdisk option to use. I have gone for the Analyse option. It's going to take a while as the drive is 1.5TB in size.
Another +1 for testdisk - that app is awesome beyond all belief.
You could try pointing it directly at the drive (ie /dev/sdb), see if it manages any better / worse.
Equally if you've sufficient space, you could use 'dd' to make an image of an entire drive. Means that if you break anything, you can rest easy.
