MDPC Sleeving - Bulk order
Status
Not open for further replies.
27 Oct 2009
West Sussex
Hi guys,
I'm slowly planning to get some sleeving done and I though as I have to get a bigger order why not get a bulk quantity of Black & Gray sleeve. We share the delivery cost between us all and then each 10m is way cheaper than buying it in 10m lots.
I would only do it with the MM confirmed purchases of required quantities so we could actually use up the lot.
I personally would need 30m, so there would be 70m spare for ppl to get.
Would any1 be interested?
At the same time we can agree I'll get other stuff for you guys but this would all go into MM posts.
Leave your feedback here so we can get this organised.
List so far:
1. qbazdz - 30m
2. shadowscotland - 10m
3. marshallman05 - 30m
4. ...
30m remaining :) (or 130 ;) )
100m of black is currently 53EUR + delivery so it works out around £4.5 per 10m +del.
Normally 10m on it's own is about £8.5+ 8EUR delivery.
Cheapest 1st Class Recorded is £1.55, so then just add a cost of 10m of sleeve.
I'd be prepared to sell them by 2m lots and I don't intend to make money on it, simply make it cheaper for myself by getting a bigger lot which is cheaper.
We can work out everything once we get at least 100m allocated to various users.
you need about 40-60m to do a whole psu. (less if modular)
But I'll take 10m @ £6ish inc
If you only want black - the Triple-Braid 'Clean Cut' stuff is a MUCH cheaper option.
That's the problem... color scheme I want cannot be purchased yet so I have to go with MDPC.
I'll start the list in the first post.
Also, would you mind getting the Shadow 19 instead of Black?
is it only black? or could you order other stuff like heatshrink, different colours, pins, tools etc?
also what sizes?
Status
