- 18 May 2010
Hi,
I'm really hoping someone might be able to point out what I'm doing wrong here because I'm having a really hard time with MDT, I've been asked to add a different version of Windows to MDT for deploying to some machines, I'm getting a bit stressed with it because all I've done for two days is read and test, read and test and I'm getting no where.
The existing config is -
1 x Windows 10 Enterprise WIM and 1 x Task Sequence to install it
I want to -
Add 1 x Windows 10 Pro WIM and associate it with a different Task Sequence
The problem lies where I've done the above, edited the Deployment Share Rules customsettings.ini to show the available Task Sequences, when I boot a machine to PXE it see's the available Task Sequences and I select the one associated with Windows 10 Pro however it then installs and follows the Task Sequence related to Windows 10 Enterprise as if my new one doesn't exist even though I've selected it.
I'm tearing my hair out trying to get my head around why this is and getting no where, can anyone help please?
Thanks in advance!
I want to -
Thanks in advance!
