Hi i did have it all picked last week but i keep changing my mind on the parts mainly the Radiator and Reservoir.
This is what i was going to get XSPC D5 Photon 270 Reservoir/Pump Combo and XSPC EX360 Radiator with another XSPC EX240mm.
What am wondering is does it really matter the size of the Reservoir will it make a difference to my temps if i went for 140 size or 270mm one am thing the more water they can hold the cooler the water will be?
And is there any difference in having the pump attached to the Reservoir or having it separate to flow rate?
Also about the Radiators i will be using SP 120`s low noise on them.
I have been looking at peoples builds on here and i did notice the build 8 pack is doing atm hes using black ice SR1 Radiators so i though well if hes picking that ones then they must be really good ones and would be better than the XSPC.
The question is does it really make much difference in temps the black ice rads to the others, guess what am asking is is the black ice ones the best ones to get.
Am sorry if am going on a bit but the more i watch on utube and reading on this forums is just making me more confused about the parts i want, mainly i want the best temps i can get on water am willing to spend for it tbh but what i dont want to do is splash the cash then find out i could have gotten better results with other parts.
Omg this must have been the longest post i have made on these forums lol
Ah one for thing about cpu blocks is it better to go with full copper ones for around £100+ or will one of the ek blocks be much the same for £50 odd?
