Me Daewoo Don't Work
7 Aug 2004
Hey All
Iv got a Daewoo Setpal DV3 DS608P settop freeview box
All of a sudden it doesnt work, been working for over a year or 2 now, then yesterday got a 'new or changed channels found' messege, as has happened a few times, got it to scan, said found nothing, so just cancelled and carried on watchin telly.
Came to switch it on again, says new or changed channels messege again, scanned, nothing, pressed cancel, then the channel list was empty and said there was no signal :confused:
Got the other freeview box from up stairs, plugged that in, sorted straight away, tried other box on all ariels in house, works fine, plug daewoo in, nothing, says no signal/no channels.
Iv reset it, done everything the manual says and nadda, any ideas fair people ?
Well, by elimination, you know that the problem is in the box itself, so drop Daewoo an e-mail is my suggestion.
