me up £500-£600 please
1 Dec 2005
Stoke on Trent
Only requirement is it has a plextor PX-755 optical drive.
just need the base unit, already got monitor, keyboard mouse speakers etc. Would prefer socket 939, but if you can get a decent AM2 or conroe system then me my guest. Wil be used for gaming, so could do with a 7600GT at least
Cheers
perhaps conroe then? as you already had 1 AMD??
whats your budget?
you could get something like this for £571 which is a conroe...
CP-126-IN Intel Core 2 DUO E6300 "LGA775 Conroe" 1.86GHz (1066FSB) - Retail (CP-126-IN)
£129.95 £129.95
MB-020-DF DFI Infinity 975X (Socket 775) PCI-Express DDR2 Motherboard (MB-020-DF)
£129.95 £129.95
MY-014-GS G.Skill 2GB DDR2 NR PC2-6400 (2x1GB) CAS5 Dual Channel Kit (F2-6400PHU2-2GBNR) (MY-014-GS)
£114.95 £114.95
GX-080-LT Leadtek GeForce 7600 GT 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (GX-080-LT)
£111.95 £111.95
Subtotal £486.80
VAT £85.19
Total £571.99
You could ditch the mobo for a cheaper one and then get a slightly faster processor...or alternatively you could keep the mobo and get at least a 2ghz cpu then you could overclock it to 3ghz+ cuz its a conroe :)
if you are looking to spend a little more you could also get a 512mb version of gfx card instead of 256mb...
£129.95 £129.95
MB-011-IN Intel DP965LT 965 (Socket 775) PCI-Express DDR2 Motherboard (MB-011-IN)
£74.95 £74.95
GX-024-BG BFG GeForce 7600 GS OC 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-024-BG)
£75.95 £75.95
HD-023-WD Western Digital Caviar Special Edition 80GB 800JD SATA-II 8MB Cache - OEM (HD-023-WD)
£28.50 £28.50
CD-018-AS Asus DVD-E616P1 DVD-ROM (Black) - Retail (CD-018-AS)
£12.50 £12.50
HS-017-AR Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
£14.95 £14.95
CA-017-TT Thermaltake VB1000BNS Soprano SuperMidi Tower - Black (CA-017-TT)
£39.60 £39.60
CA-000-SS Seasonic S12 430W Silent ATX2.0 Power Supply (CA-000-SS)
£39.95 £39.95
MY-064-OC OCZ 2GB (2 x 1GB) PC5300 Dual Channel Gold GX XTC Series EL-DDR2 (OCZ26672048ELGEGXT-K) (MY-064-OC)
£114.95 £114.95
Subtotal £531.30
VAT £92.98
Total £624.28
I'm really proud of this one :p
Oh bah ******* humbug.. Just realised thats the GS not the GT :mad:
£129.95 £129.95
£74.95 £74.95
£28.50 £28.50
£12.50 £12.50
£39.60 £39.60
£39.95 £39.95
MY-063-OC OCZ 1GB (2 x 512MB) PC5400 Dual Channel Gold GX XTC Series EL-DDR2 (OCZ26671024ELGEGXT-K) (MY-063-OC)
£59.95 £59.95
GX-025-BG BFG 3DFuzion GeForce 7600 GT 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-025-BG)
£99.95 £99.95
Subtotal £485.35
VAT £84.94
Total £570.29
Yeah! :D
If you don't mind going a bit over budget, you can have 2GB in there. But I'm proud of that one! :p
£129.95 £129.95
£74.95 £74.95
£28.50 £28.50
£12.50 £12.50
£39.60 £39.60
£39.95 £39.95
£59.95 £59.95
£99.95 £99.95
Subtotal £485.35
VAT £84.94
Total £570.29
Yeah! :D
-£12.50 on the asus +£37.95 ex vat because he wants a specific plextor drive for some reason. Looks not bad otherwise :P
That looks pretty good, need a plextor as i need full cd+g support and onlyh plextors do it properly
