Meaningful benefits
2 Oct 2007
Cardiff
Hi All,
My ageing 8800GTS reaches 82°C when playing Crysis. Has anyone has any real world benefits from installing a 120mm fan on the left side of their cases aiming at the card. The other idea I had was to create a duct that channel clean cold air straight into the intake of the fan on the card.
Also my mobo at P35-DQ6 idles at 52°C. Is this because I had to take the cooling copper plate off the underside to install the TT Extreme or because I have crap airflow. My case is a P182.
Thanks
Just got one of those blowers myself, looked like a bargain, getting fitted tomorrow alongside a Akasa Vortexx
you won't need the blower if you have the vortexx fitted. I put one on my 4850 toxic, which is also slightly oc. idle temps only dropped a couple of degrees, load temps dropped 25-30 degrees.
If I fit a cooler to my 8800GTS 320 it won't fit anything better in the future will it??
What is the best cooler for an aging 8800gts?
Thank you
Actually that's not a bad point-I had the blower under a 1950pro with only single slot cooling-if you have a dual slot cooler on your card already something else may help you more.
After fitting the Vortexx and having a sound card next to it, there was pretty much no room for the blower in mine, the cooler is huge :). Similar results to Raziel1, idel temps slightly down, but running the Devil May Cry 4 demo on max settings (at 1680x1050), my 8800gt stock cooler got to around 70-80c. With the Vortexx it refuses to get anywhere near hot, 50-55c with fan on 60% (speedfan), just awesome results and its only been fitted for a few hours, also quiet too.
Back to HatMan's first post, i have a 120mm fan on the side of my case that hits the gfx card, doesnt seem to make much of a difference to the gfx card, but does help with the overall temp of the case.
