There is a built in app on iOS that works well but I don’t no about Android.I need to measure an object to the mm is there a way I can do this with my camera and an app?
vernier callipers get nick named as very near callipers, they are ok but not as good as micrometres, it does depend and what the OP is trying to measure mind you,The iOS measure app isn’t that accurate in my experience. Accurate to within a centimetre up to around 50cm and then progressively worse.
To be honest, I don’t trust my Stanley tape measure to be accurate to a millimetre. I’ll grab a steel rule or if I have to be short accurate, a vernier calliper.
tbh i wasn't sure if the op just meant accurate or literally 1mm- as in +/- 0.5 of a mm it is also dependant on the size of the object in question as to the easiest and/or best tool to use+-1mm according to OP, for which a micrometer is massively overkill, as are verniers really!
