measurement help please?
14 Nov 2004
Hayle, Cornwall
I would like to make a door for our door extension. would any of you be able to calculate the measurements I require please?
also anyone know any companies that do bespoke fabric work?
rotters
rotters
I don't see how anyone can, as it has a curve in it. unless you just want a measurement of a rectangle that would fit over it.
brilliant guys...hehe, its an extension to our tent but due to it be open ended it becomes a wind tunnel, we thought we could make or get a door made for it, as for measurements I wasnt sure if some clever mathematics whizz could figure it out?
rotters
I'm sure you can, you could probably make it yourself if you can use a sowing machine.
As for measuremeants. You can't buy curved sheets. So it would just be a rectangle, slightly larger than the hole, so you have enough fabric to make the poll sheaths with.
I would suggest making a big paper template of it and then doing it yourself or taking the template to someone who would be able to do it.
rotters
Get another tent to put on the other side? :D
