Measuring air flow
17 Dec 2010
Northampton UK
Hi all...
I have an Antec 902 and was wondering if there is way to measure the airflow running through the sytem. The reason i ask is so i can set the fans to the right speed.
Thanks.
Steve.
WK7-uOdzc0wRSYoym4efW20-OE07wuXjnYmzKA4Q0GoDH-kEqyPNKXbNHEyJ6RzSWZoXr99tvcxPq1vDQtcDvTP2hyjwoxfNDMxmNCmV-3gbNSSnrJZZ9oPc9DuDOpdVPqRH0_FVIFMuP_GabofKAvCH_3jYJrhNEJ1VMryaxueAkACHunzf-ZO9CnwQThCshtjzUlFcskuUpt--nOXgwe7V95mlJw
You would need to buy an air flow meter. Easier to just read the specs of the fans and work it out from there, at a certain RPM the fan will produce a certain CFM.. If your fan controller displays the fans RPM you can look up the fans specs and work out the CFM.
Thanks for the input guys. I've set the two 140 mm fans on the front to the lowest speed, the 80 mm on the back to medium and the 200 mm on the top to medium. seems to be ok with variuos temperature tests on cpu,gpu and memory.
Thanks again.
Steve.
