Mechanical Keyboard with Per Key Illumination
28 Apr 2008
Hi Guys
I'm looking for a particualr type mechanical keyboard and thought I'd ask here.
So they mechanical keyboard needs to have the following:
- Cherry MX Blue switches
- Individual Per Key illumination
The only one I can find is Roccat Ryos MX Pro however cannot fund a stockist that has it with Blue switches.
Are there any other keyboard manufacturers that make mechanical keyboards with Individual Per Key Illumination?
Cheers
If im understanding your per key illumination correctly then most if not all cherry mx keyboards will be individually lit. Certainly the duckys and corsairs are.
To clarify though per key illumination being that each key on the board has an led as opposed to a dozen or so leds spaced around the keyboard in a back light style illumination
Actually, meant that the siftware for the keyboard can programme what keys are lit so you can customize.
its looking like that the only keyboard you can do this on is the Roccat.
Spent all morning goggling mechanical keyboards with individual LED lighting.
Thanks for your reply though appreciate it.
I have a Corsair Strafe and the Corsair software allows you to set profiles for each program you use so that only the keys required are lit. Each key has its own led light. I believe that all the Corsair gaming keyboards allow individual key illumination.
The Strafe RGB gets good reviews and you can choose the key type (cherry red, blue, brown or black) depending on preference.
My basket at Overclockers UK:
Total: £250.44
(includes shipping: £10.50)
The ducky shine can certainly do that and more. Plus no software needed its done with function keys on the board
Hmm can't seem to find the Ducky Shine in a Blue Switch :( would prefer it as a TKL seems that version of the Shine is now discontinued.
I have a Ducky Shine 3 TKL with blue switches and green LEDs, bought from OCUK a couple of years ago. Nice keyboard, but after a while a few of the LEDs apparently died. I guess I should have RMA'd it, but I just put it in the cupboard with the rest of my keyboard collection.
Now using a Corsair K70 RGB with brown switches - very very nice keyboard, and I think I prefer the browns to the blues now.
