Mechanical Keyboard?
12 Jul 2010
(Not sure if this is the right forum - but I couldn't see a subforum for peripherals apart from monitors.)
I am wanting to upgrade from my old G15 keyboard to a mechanical one. I do a lot of both gaming and typing, so from reading around, my impression is that Cherry MX Brown switches would be best for me. (Though I am a bit worried about the noise levels... are there any good mechanical keyboards for typing / gaming that do something to reduce noise levels?) Alternatively, people seem to praise the Topre keyboards, but I've not found much straight up comparison as far as feel and sound goes compared with the various Cherry MX models... which one of them would a Topre switch be most similar to?
I have great trouble finding a good mechanical keyboard that has a separate volume control on the keyboard, and ability to lock the Windows key, which are two important features for me... the keyboards that claim volume control as a feature often fit it in by doubling up functionality on the F-keys.
If only the Corsair Vengeance K90 had been available with Cherry MX Brown switches, then that would have seemed like an excellent option for me... but it uses the MX Red switches, which are not very good for extended typing according to most opinions I've read.
Any suggestions on what to look at? Preferably available from European retailers...
Yes I have been looking at the Corsair Vengeance K90 too.
Just wish it was totally mechanical. I have looked elsewhere, but I cannot find another mechanical keyboard that has the same G Macro Keys layout.
i have the qpad mk-50. which i love and would recommend. if you get direct from qpad you can choose what switches you want. if you want back lighting go for the mk-80 or 85
