Mechanics problem
29 Jun 2006
Sheffield
Hey guys, I'm going through my textbook and have no idea how to do this question:
A stone is thrown down the slope as shown. Determine the magnitude and direction (theta) of its initial velocity so that the stone will rise 12m and still have a range of 50m down the slope.
------12m up here
_____ <- stone thrown from left hand side
Hypotenuse 50m, top 40m, right hand side 30m. Sorry for the poor diagram.
This means it has to travel 40m in the x direction, and 54m in the y direction (12m up, 12m down, then another 30m down).
The answers are 17.74m/s at 96.7 degrees.
If I'm given one of those answers the question is easy, but finding both unknowns is a bit of a challenge.
96.7 degrees.
Surely that can't be right? Where is 0 degrees? horizontal?
So you're basically throwing a stone at 6.7 degrees off of vertical, it goes up 12m, back down 42m and yet manages to travel horizontally 40m?
Doesnt sound right to me.
If the projectile goes 40m horizontally and falls 30m vertically before hitting the slope (so has a range of 50 along the slope),
horizontally it travels 40m so using s=ut (no horizonal acceleration),
40 = (u cos theta) t
vertically using s=ut+0.5at^2
-30 = u sin theta - 0.5 g t^2
If we eliminate t we get an equation with only u and theta in it.
If initial velocity is u, to reach a peak height of 12m, using v^2=u^2+2as
0 = (u sin theta)^2 - 2xgx12
That gives us a value for u sin theta which you should be able to use to solve u and theta... I think.
Edit - not done the sum but if you eliminate u, you get a quadratic in tan theta. Also realised I got the 30m and 40m the wrong way round
