Media Center 2005 Question
kbc
kbc
20 Nov 2004
London
Hi,
I'm in the middle of building an HTPC and intend to use MCE to control everything. The connections will involve a PC, NTL Cable box and an Amplifier.
Within the HTPC - I will be using 2 capture cards, one dual analog capture card to capture NTL TV and standard Terrestrial and another DVB-T capture card for freeview.
Now if I was to use MCE, is it easy to configure it so that I can use both capture cards at the same time?
I've got 2x DVB-T tuners in here and it works flawlessly with timeshifting, recording one channel while watching another, recording 2 channels etc. Very easy to setup, but I'm not sure how it would work with 2 different types of tuners.
Once you get it setup MCE really is a great front end, especially with the amount of community support with things like hacks/mods/plugins :)
