Media Center & Dual output
24 Mar 2007
'ull
having just bought a Samsung 2232BW (gorgeous, by the way!) to use as my main display in a dual output, DualView config.
i've found that when i maximize media center it locks my cursor onto 1 monitor, deeming the 2nd monitor useless!
any ways to get round it?
ive even tried dragging the window out to fill the 22", but it appears theres only so far u can strech it.....
any ideas will be much appriciated!
Dave
Install Media Portal, you can run MP on secondary (TV) and use Windows on primary (Monitor) Use it myself....had the same problem as you with MCE. You could alt-tab out of MCE but system bogs down to a crawl for some reason.
