Media Center Remote Sensor?
8 Jul 2006
Hiya Everyone
As you know, with a Media Center computer you usually get a remote control and a remote control sensor. What connections are on the sensor? I know there is a USB for the computer side but I think theres other connections for cable and things? If your not using cable or a TV tuner will the remote sensor just work if its only using the USB?
Sorry for nto explaining very well! :p
The MS IR receiver dongle has two 3.5mm connectors, two IR blasters are included. So source and amplifier could be hidden, but the MS reciever is in view. The MS receiver transmits any signal to the blasters, so any hidden device works. You place the blaster in front of the device IR window.
This is done for custom installs usually.
