Hi all,
I have been looking at a running a 360 downstairs to connect to the PC upstairs in order to steam the films i've ripped from my DVDs. However, no matter what I try I can't get the 360 to read from it via wifi.
So, I am going to look at building a media PC and running win 7 on it.
I've a couple of questions about it. I've been playing with media centre for the last couple of days and it seems pretty good, I've been looking about and managed to find YAMMM to give synopsis info and IMDB ratings. However, i'd like the ability to create custom synopsis and add our own rating system to the films. Is this possible and if so, how?
Also, I've been compressing movies down to make them more manageable, however, I want to create a surround sound system either internally or externally from the media PC. Will surround sound work with compressed video or will I really need to look at just copying the DVDs straight over unaltered?
Any good sites for media pc's/media centre?
then it's just a case of lifting the odd floorboard etc to run it in. I've recently bought a new house and the first thing we did (before carpets etc went down) was to run CAT6 everywhere. All in all, including all the CAT6 cable (which wasn't cheap, or probably worth the premium over Cat5e to be honest) a 16 port patch panel and all the wall sockets came to about £250. If you use CAt5e and just terminate with RJ45 rather than fit wall sockets or patch panel should cost you a fifth of that.
