EDIT: Finished! Pics posted below
Problems:
firstly, i was expecting a low quality PSU to be shipped with case but damn! that is a new low on quality!
im not even going to turn that one and whats with the 13amp fused plug im not building a nuclear power station!
so im using a HIGH quality 450w corsair PSU i had spare (way too much for this low spec system but does the job)
another problem with the case is the front panel is loose on the bottom-right corner and as far as i can tell its not designed to be a removable panel
moving on to the HDD its B-Grade its 250 GB no damaged sectors, but when i plugged the sata cable in i notice the board on it has a slight 'wobble' like theres maybe a screw missing? i didn't check but will have to look at it later
moving on... (not all bought from ocuk) (mix-n-match job)
SPECS:
RS400-A mobo (for SKT775)
P4 3 GHz HT
1 GB DDR2 RAM
7300 GS
250 GB HDD SATA
16x DVD-rw IDE
Arctic freezer 7 (AMAZING COOLER!!! need to get another one for my main pc) (old pc have a bad overheating + 4500 RPM cpu fan problem)
and the 450w corsair PSU
questions: both the mobo and cpu allows for 24/20 pin and 4 pin connectors i went with 20+4 pin setup as thats what i was using before, if i use 24 pin does that mean i would have too disconnect the 4 pin? and i ran a psu tester on the psu before installing and the -5v light didn't come on but pc works fine? what does this mean?
thats it for now think i have more questions later but going to rest for now
Problems:
im not even going to turn that one and whats with the 13amp fused plug im not building a nuclear power station!so im using a HIGH quality 450w corsair PSU i had spare (way too much for this low spec system but does the job)
SPECS:
P4 3 GHz HT
1 GB DDR2 RAM
7300 GS
250 GB HDD SATA
16x DVD-rw IDE
