Media Centre help needed!
29 Jul 2004
Bristol
Hi all, after having MCE working nicely on my 32 bit vista ultimate install, it has recently hit the fan. Having changed absolutely nothing, it simply crashes whenever i enter the video library. I notice in the split second i have to see the library that theres no local disk c being searched, and im pretty confident its crapping out on trying to thumbnail a funky file in there or something similiar.
I tried removing all my files from the library list but its made no difference, the same folders appear and the same crash happens.
Any suggestions? Is there anyway i can actually uninstall the MCE portion and reinstall it? Or just clear the library even?
I've googled a fair bit on this with no luck!
zobby said:
Possibly wont work, but have you tried installing a windows vista codec pack like Klite? I had this problem and basically it was a corrupt codec. Reinstalling the codec pack did it for me!
http://www.free-codecs.com/download/K_Lite_Codec_Pack.htm
Hmm that vageuly helped. In windows i still get the same crash, but my 360 now works as an extender as long as im not logged into the machine... weird.
