Media Centre Library problems!
18 Oct 2002
North Wales
I'm having problems with the Music Library in Media Centre, but only via an extender.
I've recently had to move my music library from the root of one drive (E:) to a sub-directory of another (D:).
Windows now has D:\Music set as it's default Music folder, WMP12 has the same folder set as it's media folder for music. Media Centre itself (via windows) has D:\Music set as it's music folder.
All is well, except when I'm using Media Centre via an extender, which doesn't show any music. If I add the D:\Music folder manually, it doesn't add any music - unless I insert a USB stick in and allocate that to E: - when it adds music fine! If I remove the stick, the music goes with it!
I cannot find any references to E: anywhere in the registry, or elsewhere. Does anyone know how I can delete all the media centre libraries etc, so it might reset itself maybe?
Or any other ideas?
