My dad wants to know if I can build him a media centre PC. I'm pretty happy with doing this but there are two questions.
1) In short, how can you provide SCART output from a computer with only DVI, D-Sub (VGA) and HDMI outputs???
I ask because his current TV is a large 32" widescreen CRT (quite an expensive unit when he bought it a couple of years ago). He is going to replace it with a LCD or Plasma in 1 to 2 years time but for the moment will be keeping the TV..
This means the TV supports a SCART input rather than any HDMI or DVI input you'd find on a LCD TV.
Therefore, how can I build a media centre PC with this sort of output? He did specifically say he wanted a HDMI socket on the media centre PC for when he gets the LCD so I was going to use the "Abit Fatal1ty F-I90HD ATI Micro ATX" motherboard as this has a HDMI socket (it also has a DSUB socket and a HDMI to DVI adaptor).
I know the TV probably supports RGB component cables (think it's sometimes known as Y Pr Pb) as well if this is any easier?
2) Second question, he'd like to use the Media centre pc to convert some of his VHS tapes to DVD. Therefore what is the best way of providing video input from a VHS player to a media centre PC. Idealy I would like it to be as easy to use as possible so if he can simply go into the Media Centre interface and watch the VCR playback in there just like a tv chanel that would be a bonus cause then he could simply press play on the VCR and then press Record on the media centre pc and record his video just like it were a tv program.
