Hi,
I am going to build myself a media centre PC with a completly scratch built case (Will be asking for tips and suggestions in Case Central soon
) using parts from my old machine which consists of:
AMD 64 3200+
Asus A8N-VM CSM
1GB PC3200 RAM
400W Enermax Liberty
80Gb Samsung SATA Drive
Sony DVD-ROM
I will use my current 24" Phillips CRT as a display for now until I can afford a Plasma screen. Now, I'm going to be using MCE 2005 with this and will obviously need a TV card and thought about getting a freeview one but am stuck for choice. I don't know how to get the signal from the PC to the TV either- the motherboard has both VGA and DVI onboard but the TV only has scart or component input
I've seen a thread further down but the cable being linked to is a Scart to VGA whereas I need VGA > Scart and I'm also not paying £60 for a bit of wire! Are TV cards avaliable that can output a component signal as well as using a standard RF input signal? I don't know much about this sort of thing so could do with some help- any tips and advice would be useful
Also, in my custom built case, I plan to mount a 4" LCD with which I plan to send a graphics signal to off the PC and use it as a sound meter type thing if I can find a program that will do it... any suggestions?
Thanks for any help
Ben
) using parts from my old machine which consists of:AMD 64 3200+
Asus A8N-VM CSM
1GB PC3200 RAM
Sony DVD-ROM
Thanks for any help
Ben
