Media Centre Software... multiple dual tuner cards
18 Oct 2002
All,
bit of a random question...
I'm looking at building my first HTPC and I ideally wanted to put 2 dual tuner freeview cards in (so that I can potentially record 3 channels and watch 1 other)
Has anyone done this, and if so, using what software/OS ....
Would appreciate also knowing which cards you used, or, if a quad tuner card exists !
many thanks
OzyOly said:
MCE05 can't do this without reg hacks. Vista can I believe. What dual tuners were you wanting to buy?
I havnt fully specced up the system yet, but basically i'll buy whichever cards will work... Vista Home Premium is the OS id need right?
whoops, used the wrong account again :mad:
as for media portal, I have that on this PC now, looks pretty good to use... and being free helps ! however I have been quite happy using windows media centre on a mates HTPC, so if vista can do it... id probably go for that
Media Portal works fine on Vista, I have it on my gaming rig (Vista OS), and on my HTPC downstairs (XP). I have it on Vista upstairs, coz I need to have it installed for the TV server to work (stream TV up to my room).
would you mind to listing down all of your hardware and all software/codec installed
no matter what i do i cannot get any video running smooth in media portal, but perfectly on MCE, even on same machine
thanks
thanks
sure will do, off to sleep right now though, will do tomorrow for ya mate.
one thing I can say though, is that I do NOT install any codec packs, I only installed a few codecs, and it's all i needed. My MP plays everything I can throw at it, even finally got Daemon Tools to auto mount a image and play it... took me ages to get it right :p
