Hi, I need some help and advice with my plan if anyone can provide….
Usage:
I want to build a HTPC to go into the living room
It will be used mainly for recording Freeview TV, playback of DVD's, Music, Pics etc
Iplayer/catchup TV also would be good
May also use it with a webcam and Skype for family chats
This will output/connect to a 32" LED TV (at some point when I get one - still stuck on a 22" CRT ATM!)
I would like to have 1 small boot SSD for speed and a larger storage HDD for TV recordings and DVD backups (2gb or so)
Lan connectivity will probably be via homeplug route - longer term I am thinking of getting a NAS drive for TV/Data backup
Lots of question areas from my research into this: (feel free to comment and advise me on these areas if you know anything
I would like to control it via a remote and have from ages ago a windows xp media centre edition remote (with USB IR receiver) is this still compatible with Win7?
Does it work with other media apps?
Have also been looking at the "Rii Mini PC Keyboard Touchpad V2 Black" for touchpad and keyboard - any comments/views on this one?
Thought this might make use of the PC a bit more practical day to day
I am thinking of getting a Samsung UE32D6530 LED TV to hook this all up to - what kind of connector route is used to output vid and sound to the TV?
HDMI? Or some other method? What do GPU's output to these days?
Case - I have an old case from around 5 years back which I used for windows xp media centre edition 2005
I think this is a coolermaster atcs case - possibly this one - ATC-620-SX1 (silver) (at least the picture looks just like the case I have)
http://www.dansdata.com/atc620.htm
Do you think I will be able to re-use this for a modern system?
I am not 100% sure of this as I don’t know if modern PCI express cards will fit in the case and the back plates?
It currently houses an old set of parts (which wont boot for some reason) - an ASUS P4P 800M, Pentium 4 - 2.53GHZ, 2 x 512MB Corsair XMS 3200, and an AGP GPU
I think it is micro ATX form factor
If this is not usable any other cases I could try?
Note - that the PC will need to slot into the gap under the TV:
Width = 45cm
Height = 16.5cm
Depth = 50cm
Also I want to have room in the case for a TV card so any case must allow the addition of one of these as well as a GPU
Sound from the PC - do motherboards come with reasonbably good soundcards these days?
Short term I would just have the sound via the TV - but longer term maybe output to some speaker system
TV card - I currently have 2 very old blackgold GDI Freeview tuners (PCI) single tuner cards
I am thinking of getting this card when it comes out (BGT3650):
http://shop.blackgold.tv/epages/BT3159.sf/en_AU/?ObjectPath=/Shops/BT3159/Products/BGT3650
If I understand correct this will allow recording of 4 Freeview HD channels at once?
My area has just had the TV signal switched
Will this card only work with media centre or will other apps work with the card (i.e. pickup the TV signal?)
Again my questions on compatibility with the case here apply again - will it fit as I think this is a PCIE card?
(Will a GPU and this card fit in the case together?)
Heat, noise and energy consumption are I guess of note here - less for all is better
However I do not want super slow equipment which will be unable to do what I want it to
With this in mind - what sort of motherboard/CPU/cooler/mem/PSU/GPU combinations would people recommend (in light of the above TV card and case choices)
I was thinking of a Z68 Motherboard with maybe an I5 2500K with 4-8GB of DDR3 Ram?
Is this good/bad in terms of heat/noise/performance/energy use constraints?
What motherboard brands are good - and which to avoid?
What GPU? I don’t want something too slow unable to handle things
What PSU to power it all - quieter the better!
I have read some tales about people having issues with Media PC's and suspend resume:
Not going to sleep when told via the remote
Not waking up to record
Not shutting down after recoding
Once sleeping - waking up again for no apparent reason
Anyone know much about this - is this now ok in Win7?
I don’t want the machine on when it doesn’t need to be - but I also don’t want it missing recordings from not waking when it should!
Do I need to use windows MCE for the media playback or can other 3rd party apps now do the job better (if so which)? (and also do they interface with the TV card's ok?)
Do 3rd party apps work ok with suspend/resume (waking for recordings and sleeping when done?)
One app I read about is XBMC - any good?
This may be non-legal - cant remember 100% if it is or not (if it is don’t worry on this one)
But what format would people recommend to backup their DVD's to for playback via a media app?
MKV is one I read about - any others?
I guess MCE will not play these - but do others support it?
TV Arial - I would need to split this somehow so one end goes to the TV and one goes to the TV card on the PC?
Anything around here I need to know or think about?
I guess other questions will arise but lets see where these lead to for now
Thanks for any input, Neill
Usage:
Width = 45cm
Height = 16.5cm
Depth = 50cm
