- 5 Jan 2013
Hey,
I currently have an overclockers Titan Decimator (TD) that I am going to strip out and build a PC for my front room, I will mostly be using for streaming video (SD & HD) to the TV, but will also use it for some light gaming (Steam Big Picture & an xbox controller FTW)
So I would really like to do this on the smallest possible budget and build it into the smallest possible case. No fluorecent lights,leds or any of the gaming PC razzamatazz (To quote my wife "it must be small, look grown up and subtle)
what do you recommend i replace from the TD,and what shall I salvage? I am happy to run onboard graphics and sound (but I may get a low powered cheap Gx card upgrade in the future)
The Decimator spec is as follows:
System Specification
- Case: Antec 300 Gaming case - Black
- Power Supply: Corsair Extreme 600W
- CPU: AMD Phenom II X6 Six Core 1055T 95W Edition 2.80GHz overclocked to 3.80GHz
- Motherboard: Gigabyte GA-880GM-UD2H 880G
- Cooler: Titan Fenrir CPU Cooler
- RAM: Corsair XMS3 (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Hard Drive: Seagate Baracuda 7200.12 500GB 16MB Cache
- Graphics Card: Intergrated ATI Radeon HD 4250 with HDMI, DVI and VGA ports or a choice of latest DX11 cards.
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
- Cooling: 2x Xigmatek Crystal White LED Fans
