Media Player Classic Home Cinema Updated, awesome 64bit too.
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
Download: http://mpc-hc.sourceforge.net/download-media-player-classic-hc.html
Changelog:
v1.3.1249.0 - 26 august 2009
NEW : Support for Flac audio streams
NEW : Support for Dolby Digital+ (Eac3) and Dolby true HD (MLP)
NEW : Nellymoser audio decoder
NEW : Belarusian, Brazilian and Sweedish translation
NEW : New shader "Sharpen Complex 2" (required hardware compatible with pixel shader 2.A)
NEW : Support for madVR video renderer (http://madshi.net/madVR.zip)
NEW : Additional information on video using MediaInfo (DLL can be download from http://mediainfo.sourceforge.net and placed in mpc-hc directory)
NEW : Internal DXVA decoder support for H264 with Intel G45 (thanks for people who help me at Intel Corp.)
CHANGED: Add support of interlaced flags in software mode for MPCVideoDecoder filter
CHANGED: D3DFullScreen mode now takes into account the monitor to full-screen mode in options, if monitor is not specified on the command line.
CHANGED: Auto-hide playlist on fullscreen(feature request #2219561)
CHANGED: Detours library updated to v2.1
CHANGED: Support for AC3 in MP4 splitter
CHANGED: Support for EAc3 in Matroska splitter
CHANGED: Hotkeys added to support more remote control keys
CHANGED: Support for Theora in Matroska internal splitter
CHANGED: LibVorbis updated to v1.2.3
CHANGED: LibOgg updated to v1.1.4
CHANGED: Improved streaming performances
CHANGED: Prevent display or computer to sleep during playback
CHANGED: Faad library updated to rev 2.2.7
CHANGED: LibPNG updated to release 1.2.38 (fix security bug)
CHANGED: Playlist file is now saved in mpc folder (patch # 2671496)
CHANGED: frame by frame modify to support step frame back functionality (except for VMR9)
CHANGED: support for AC3 in MP4 files created by Nero Digital
CHANGED: EVR custom and VMR9 renderless revamped (Beliyaal), better synchronisation, remove tearing in windowed mode, support for dialog box in DirectX exclusive mode, ...
FIXED : Support for Theora stream in Ogg internal splitter
FIXED : Save thumbnails crash in x64
FIXED : Bugs on presentation graphics (missing subtitles, better synchronization)
FIXED : Audio change on M2TS files reset the selected subtitle
FIXED : Switch to "Minimal view" reset main menu language to English
FIXED : Bug in Mpeg splitter for VC1
FIXED : Maximum texture resolution to "Desktop" not working with Haali renderer (Bug #2456735)
FIXED : Better synchronization with EVR custom to improve playback smoothness
FIXED : 24 bits LPCM not properly play
FIXED : Possible deadlock with Reclock
FIXED : Support of framestep backward, even if the codec didn't support it natively (bug #2600542)
FIXED : DXVA decoder support multiple graphics cards (PCI vendor id detection on the fly)
FIXED : Incorrect aspect ratio for some H264 files with DXVA1 decoder (extended SAR)
FIXED : H264 files with 16 reference frames freeze during playback (bug #2795785 and #2784256)
FIXED : AVI with H264 not decoded properly (bug #2794854)
FIXED : Revamped DXVA h264 decoder based on new insights, fixing black screen, macroblock, support for AVI, ...
FIXED : Incorrect playback for padded DTS
FIXED : Hang when moving player between monitors
I was running only the 32bit version but now with this new x64 version I enabled all filters except Mpeg1 and matroska (default behaviour) in MPC and BAM! It plays everything I have with multiple audio streams, subtitles etc all perfect and best of all it loads those same files virtually instantly whereas external decoders under 32bit took 1-2 seconds to initialise then start playing the video.
720P and 1080P decoding of my own BR rips picture quality side by side compared to DIVXHD and FFDShow is identical so I have decided to stick with 64bit MPC-HC only now running in hardware decode mode via DVXA :D
Win7 x64 here btw....tempted to uninstall all codecs I have now as I only use MPC for movie watching since I don't need codecs at all any more!
Oh yeah, if your old 32bit or 63bit versions were saving settings to an ini file you'll have to set that option again then copy your backed up mplayerc.ini over and rename it mpc-hc.ini and a 64bit version for 64bit if you use just that.
Handy if you've tweaked your key settings like me somewhat and have favourites saved in the bookmarks area :)
oh phooey. this works with some of my mkvs but not others. i have some where subtitles don't load and the context menu item is greyed out. :confused:
edit: working fine in vmr9 renderless mode - just not evr.
Just a quick headsup, the 64bit version can only use 64bit codecs. It comes with a suite of it's own codecs but if you use anything extra (CoreAVC, Matroska Splitter or AC3 Filter for instance) you're out of luck.
It's an awesome bit of software that I use for watching everything, but I'll sticking with the 32bit version for the time being.
Anyway, even on huge 45gb BluRay movies, it doesn't come close to using the ram to require 64bit, and as for performance the same film barely tickles the CPU as it is.
AnyDVD :)
BTW Matroska splitter works with 64bit version, splits my subs just fine in MKV files :)
The 'official; builds are rarely updated, get the dailies here - http://www.xvidvideo.ru/content/category/1/1/2/ .
Margaret, you only need MPC-HC unless you specifically need ffdshow for something (AviSynth scripts, advanced tweaking - power user stuff). No need for Haali unless you use the Haali renderer or want to set automatic audio/subtitle preferences, MPC-HC has the splitter built in.
I think you need Haali as the default renderer has blocky playback on 7.
Unless you can use another built-in renderer that works fine under 7, I usually just switched to Haali.
Thanks though, am I right in assuming MPC-HC will go off my sound card settings? (need 5.1!)
Oh nice this new MPC-HC has been updated and no longer has the blocky playback under Windows 7 issue, that's great.
Seems good so far! Sorted the issue with MPC not playing my DVD's properly (skippy playback) my DVD drive firmware needed updating. (although VLC played DVD's fine)
I've used MPC for many years but this one aint right. Wrong aspect ratio & cropping the image:
I'll continue trying to fix it but ATM I can't recommend it to anyone.
EDIT: After a bit of farting about I fixed the above problem by disabling VMR9 mixer mode in Playback > Output options. As mrk said the hardware acceleration in this is great for HD content. Playback of a 1080p file used about 20-25% CPU usage with ffdshow but now takes 1-5%. :D
There's something wrong with your aspect settings then, right click change video frame or pan/scan settings.
Default reset is numpad "5".
Your issue is not a widspread issue, it is isolated to your config and a small number of others only.
