Media Player is great. Sometimes when you close it the music keeps on playing until you forcefully close it with task manager,
same goes for porno videos - when you really need to close it there and then, the audio keeps on playing
. When you choose a new track, it sometimes takes 10 seconds to play the blasted thing. It hangs frequently for a few seconds for no reason. The search facility also hangs the whole program, fn useless. It completly bombs out when you try and play certain 'supported' video files.
When you're in the 'Album Artist' section of the tree, you type in the letters to find your artist and it suddenly hops right down to 'Playlists' for no reason.
This feature also fails to understand artists that begin with "The". When you want to delete a track, it takes forever. When you edit a group of tracks using the 'Advanced Tag Editor' it rarely actually edits them. There are countless other little bugs that make Media Player a horror to use.
Is it just me or does this program really suck ass?
edit: I'm using version 10. Is that the best you can do, Microsoft?
. When you choose a new track, it sometimes takes 10 seconds to play the blasted thing. It hangs frequently for a few seconds for no reason. The search facility also hangs the whole program, fn useless. It completly bombs out when you try and play certain 'supported' video files. When you're in the 'Album Artist' section of the tree, you type in the letters to find your artist and it suddenly hops right down to 'Playlists' for no reason.
