Guys i have an album which has no album art i used to be able to right click on the album and autotag from web and it would search amazon and find the album art. But now im getting a message "Couldn't show results: HTTP/1.1 400 Bad Request"
Ive tried changing provider to amazon.co.uk still no luck.
Also into options/network. There are proxyserver and freedb settings but i have never had to go into here before to gain a connection.
The only thing thats different is that its a newer version of media monkey and also i am using a pci wireless card to connect to the net rather than ethernet which i was previously when i had connection...
Any ideas? Anyone had this problem.
Or does anyone recommend using a different program to MM even though i enjoy using media monkey.
Cheers!
Cheers!
