See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.Collections.ArrayList.get_Item(Int32 index)
at MediaPortal.Configuration.WizardForm.nextButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///D:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Configuration
Assembly Version: 1.0.2375.32811
Win32 Version: 1.0.2375.32811
CodeBase: file:///F:/Program%20Files/Team%20MediaPortal/MediaPortal/Configuration.exe
Core
Assembly Version: 1.0.2375.18796
Win32 Version: 1.0.2375.18796
CodeBase: file:///F:/Program%20Files/Team%20MediaPortal/MediaPortal/Core.DLL
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
TVCapture
Assembly Version: 1.0.2375.18798
Win32 Version: 1.0.2375.18798
CodeBase: file:///F:/Program%20Files/Team%20MediaPortal/MediaPortal/TVCapture.DLL
System.ServiceProcess
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.ServiceProcess/2.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
System.Xml
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
DirectShowLib
Assembly Version: 1.4.0.19211
Win32 Version: 1.4.0.19211
CodeBase: file:///F:/Program%20Files/Team%20MediaPortal/MediaPortal/DirectShowLib.DLL
System.Runtime.Serialization.Formatters.Soap
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/2.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll
RemotePlugins
Assembly Version: 1.0.2375.18799
Win32 Version: 1.0.2375.18799
CodeBase: file:///F:/Program%20Files/Team%20MediaPortal/MediaPortal/RemotePlugins.DLL
System.Data
CodeBase: file:///D:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Accessibility
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
TaskScheduler
Assembly Version: 1.1.1007.26951
Win32 Version: 1.1.1007.26951
CodeBase: file:///F:/Program%20Files/Team%20MediaPortal/MediaPortal/TaskScheduler.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
