this is fresh install, also it wont start from launcher I have to use main exe I get this error if i click play from launcher
Going to D/L update again
error is
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception: No application is associated with the specified file for this operation
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at CoreLib.Action_LaunchExecutable.Execute()
at CoreLib.ActionManager.Trigger(String name)
at Launcher.LauncherMainForm.ButtonClickTrigger(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at SkinLib.SkinnedButton.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at SkinLib.SkinnedButton.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
Launcher
Assembly Version: 1.0.2669.20298
Win32 Version: 1.0.2669.20298
CodeBase: file:///D:/Program%20Files/SEGA/Medieval%20II%20Total%20War/Launcher.exe
Win32 Version: 1.1.4322.2379
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
CoreLib
CodeBase: file:///D:/Program%20Files/SEGA/Medieval%20II%20Total%20War/CoreLib.DLL
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
SkinLib
CodeBase: file:///D:/Program%20Files/SEGA/Medieval%20II%20Total%20War/SkinLib.DLL
AxInterop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///D:/Program%20Files/SEGA/Medieval%20II%20Total%20War/AxInterop.SHDocVw.DLL
Interop.SHDocVw
CodeBase: file:///D:/Program%20Files/SEGA/Medieval%20II%20Total%20War/Interop.SHDocVw.DLL
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
UpdateLib
CodeBase: file:///D:/Program%20Files/SEGA/Medieval%20II%20Total%20War/UpdateLib.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Microsoft.DirectX.AudioVideoPlayback
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///c:/windows/assembly/gac/microsoft.directx.audiovideoplayback/1.0.2902.0__31bf3856ad364e35/microsoft.directx.audiovideoplayback.dll
Microsoft.DirectX
CodeBase: file:///c:/windows/assembly/gac/microsoft.directx/1.0.2902.0__31bf3856ad364e35/microsoft.directx.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
