Medion Akoya Mini E1210 netbook
19 Dec 2005
Aberdeen/Aberdeenshire
i just got one of these netbooks from my local supermarket to night and i'd like to say i am impressed for the £179.99 - vat reductin of £3.14 so works out at £176.56 and staff can get 10% off it like i did and mananged to bag it for £158.
ok there may be better ones out there but for a bargin that i have come across i'd say its ok. From what some of the reviews it says its a rebranded msi wind and so far its running
win xp on 80gb hard drive
1gb of ddr ram pc2 5300 looks to be soldered on
crucial shows ram slot empty and can be upgraded to 2gb of ram.
but what i want to know is can i buy a 2gb stick and put it in or do i have to buy a 1gb stick and put it in as system is showing 0.99gb of ram.
graphics is 64mb
and does any one know where i can get a keyboard cover for this netbook to protect my keys
and a good case slip case and a bag to pop it in along with mouse and charger and also need a usb dvd rw drive self powered if possible
Genuine Microsoft® Windows® XP Home
Intel® Atom TM Processor N270 (1.6GHz)
Intel® Graphics Media Accelerator 950
based on PCI-Express technology
Integrated loudspeakers
10" TFT widescreen display
1024x600 pixels
80GB hard disk
1GB DDR2 SDRAM
Integrated webcam and microphone
Multi-format memory card reader
SD, MMC, MS
Wireless LAN 801.11b/g Draft-N
up to 300 mbit/s* and 802.11b/g compatibility
Fast Ethernet LAN port (10/100Mbit/s)
External AC adapter
Li-Ion battery
Interfaces
3x USB 2.0
1x LAN (RJ45)
1x VGA
1x Microphone
1x Line Out
Weight and Dimensions
Weight: 1.2kg inc. battery
Dimensions (WxDxH): 260 x 180 x 19/31.5 mm
Software
Microsoft® Windows® XP Home Edition (SP3)
Corel® WordPerfect Office X3
OEM Versions preinstalled and /or on CD/DVD or recovery DVD
Warranty
12 months
battery life is about 2 hours but you can get bigger batterys to make it last 3.5 to 4 for about £35 to £45 online
