Well this may go on abit
I went to do an oil change on the accord and also knew that there was a slight leak from this little rubber blanking cap . So the oil is out and the new oil filter is on - Good job I thought - Removed the vtec soliniod (gasket intact)
Went to remove the blanking cap and this is where the fun begins . It wont come out from the outside of the block and I tried to remove the top of the block to get it out from the inside and 2 of the bolts will not undo , They are just turning so I cant take it out that way at the moment .
Any ideas please guys
Regards Skywalker
Regards Skywalker
