My plumber has installed a Megaflo HP system and we have two digital showers. However we dont seem to have enough flow rate to run both showers at once. The valves for the showers are in the loft and one of them has an app that shows the water pressure at the valve - 2bar with everything turned off. This drops to 0.7bar when both showers are running (dribbling).
Is an accumulator tank the solution to my issue? My Megaflo is 280L so we have enough hot water for 4 people to shower, does the accumulator need to be 280L also?
My plumber says a vertical accumulator would be better than horizontal as it would have a greater head of water, but I thought accumulators worked off mains pressure, not head of water. I'd rather have a horizontal so I can tuck it away in the loft.
Thanks in advance.
Paul
Thanks in advance.
Paul
