- 14 Jul 2005
- Birmingham
Hi all.
Any ideas appreciated.
Girlfriend's flat has a megaflow unvented hot water cylinder which feeds a thermostatic shower and the hot water taps.
The flow from the shower is barely a trickle when set to a warm/hot temperature and the shower is 'pulsing' as if it is trying to seek a temperature, but when set to cold the pressure and flow seems fine.
Hot water flow from the other taps is ok but not great.
The water is hot enough, the electric immersion elements work fine.
The system is so simple I'm really not sure what could possibly be the issue. Mains pressure in, mains pressure out surely. Could it be the thermostatic shower unit?
Apparently it's been getting worse since Severn Trent were working outside in the road, but cold pressure and flow seems fine (not measured though).
I'm trying to do the procedure to restore the air gap, but nothing is coming out the tundish. I can hear faint gurgles and clunks coming from the cylinder though. No idea if this would be a symptom of low/no air gap or not.
Thanks.
Thanks.
