Thought some of you might be interested in the Megajolt build I have done for my Westfield.
Info on Megajolt
http://www.autosportlabs.net/index.php?title=MegaJolt_Lite_Jr._Users_Welcome
Basically it uses the coil and EDIS(Electronic Distributorless Ignition System) along with an ECU to control the sparks to your plugs in laymans terms.
So once you have ordered a Megajolt you get the bits below in the post.
A few hours soldering and testing then you end up with this
After building the ECU you have to test you have comms with your pc(I am on my third laptop now as all the batteries are knackered on mine lol and on my main pc I have tweaked it using NLite and removed the serial support
Before you can get the ECU installed you have to do a little more work fabriacting brackets and mounting a trigger wheel for the Crankshaft Position Sensor(CPS) to reference from and (in my case a Throttle Position Sensor-TPS) to work out engine load.
Trigger wheel and bracket below
TPS bracket and sensor below
I went for a TPS based system as on my car I have twin Dellortos and would not be able to get a clean vacuum signal if I was to base it on Manifold Absolute Pressure(MAP) but if for example it was a single carbed vehicle or even ran a turbo this would work better.
I have no pictures of the EDIS and coil mounted yet as I am still tidying the loom.Currently on wiring loom mark 3 at the moment as I keep modifying it to make it neater and probably will be again tomorrow.
Whilst I was fabricating stuff I decided to make a bung to blank off the hole where the original distributor would be.
Pictures to follow as it wont let me add them to this post if anyone is interested.
Info on Megajolt
