Hi
I've recently been given two bottles of Meguiars products.
They are:
'Deep Crystal System
Paint Cleaner'
and
Carnauba Wax'
The Paint cleaner is the step 1 product and the carnauba wax is the 3rd step.
Both the bottles are dark red in colour so are probably from the same range.
I want to give my car a good wash over the weekend as well as polish and wax it.
Can i use the Megs products or would i need to buy the step 2?
At the moment i use another cheaper wax for my car but have run out of polish.
Could i use the paint cleaner in place of the polish and the carnauba wax to seal to paint?
Is it 100% necessary to use the Megs products in stages or is it just for best results?
Thanks
They are:
Paint Cleaner'
and
Carnauba Wax'
Thanks
