Okay I will try to do so. I dont know why but my hands are going crazy when i take pictures. I get someone to do it for me so you guys can see better quality images. Sorry again for bad quality images.good start with the build
Nothing wrong with his camera just needs to be a bit more steady and not to rush when taking photos
I don't know as this will be my first water cooled system. I know the procedure how to connect it but I dont know what to buy. It would be great guys if you can recommend something up to 350 pounds. Also do sp120 peformance edition undervolt well?any issues?
yes that would be absolutely fineI also found this fan controller Lamptron CW611 would it be also good for fans and pump?
Oh sh.. forgot to say CPU GPU:
CPU: I7 4770k
GPU: EVGA 780 SC ACX
Okay but would it make difference if run x2 240mm 40mm thick vs 360mm 65mm thick? Also how should I connect them what order (push/pull) it would be useful if someone can draw it on image above thanks.
